10 bolt vs. Dana 44 question.........
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MOABDADC22, Aug 27, 2003.
  1. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    My K5 (86) came with 10 bolts originally, but a 44/12 was swapped in and not finished. Are the front calipers different from a 10 bolt? If so, what years came with 44/12 bolt so I can buy new calipers/pads/etc.... I would rather buy new stuff, especially when I do not know the history of the old.
    Any help is appreciated. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/thumb.gif
    OhYeah....I know, I know......"save all the trouble and swap in a 60/14." Someday /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gifSomeday /forums/images/graemlins/thinking.gif
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    The calipers/pads/rotors are the same between 10 bolt and D44. Everything from the knuckles out is the same. Assuming internal hubs on the D44 of course. /forums/images/graemlins/thumb.gif
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The only difference that I can think of is that the 10-bolt calipers used a metric banjo bolt that's just slightly smaller in diameter than the Dana 44 calipers banjo bolt.
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Harry summed it up with the banjo bolt, I have a 74 d44 with 10 bolt backing plates and calipers on it so I can run the standard fitting extended brake lines
  5. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    So all I need is a 10 bolt banjo fitting? /forums/images/graemlins/1zhelp.gif
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If you use your calipers off of your old axle, or buy calipers that are meant for your old axle, then you can continue to use the brakelines that are on your truck now. /forums/images/graemlins/thumb.gif </font>
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    It's possible that you have the calipers from the 10-bolt on there now. When doing the axle swap they could have just left the calipers attached to the truck, so they wouldn't have to bleed the brakes again. But figuring out which caliper you have might be tricky. I don't know of any visual cues other than the metric banjo bolt fitting. /forums/images/graemlins/frown.gif
  8. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    What years came with 12 bolt fronts? I didn't know they existed.... not that thats saying much for me... /forums/images/graemlins/confused.gif
  9. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    they had 12bolt fronts the same years they had 14bolt fronts.
  10. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> No years, they were never made. I think that when Bob says 44/12 he means 44 front 12 rear. </font>
  11. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    o......
    /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/blush.gif
  12. fad2blk99
    Feb 19, 2001
    860
    Charleston, SC
    Smart /forums/images/graemlins/ignore.gifss.... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
