10 Bolt vs. Dana 44
Discussion in 'The Garage' started by Dilbert73, Jan 11, 2005.
  1. Dilbert73
    Dilbert73 Registered Member
    May 14, 2003
    19
    Fresno, CA
    I am looking to pick up some 3/4 ton axles, hopefully to have the front replaced someday with a Dana 60. I KNOW I want the Corp 14FF for the rear, but what is the best 3/4 ton choice for the front, 10 Bolt or Dana 44? In the "For Sale" forum, there is a 10B/14FF combo for sale in my area, in the ratio I want. I thought the 10B only came in the 1/2 ton vehicles. Does it really matter, between the two? I searched for info, including in the technical section, but can't find the answers. Your assistance is appreciated.
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Both the 10 bolt and the D44 are 1/2 ton axles. They get called 3/4 ton when the have the 8 lug outers, and get paired up the the 14 bolt.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    they are almost identicle in strength, same ring and pinion size, same size axles, both necked down to the same size IIRC.
    d44 were up to 79 and 10 bolts started in 78 from what i have found. you can get them in 1/2 ton or 3/4 ton.
    i like a 10 bolt over a d44 because the axle shafts are easier to find.
  4. k5redneck
    k5redneck 1/2 ton status
    Jun 24, 2004
    1,000
    mesa AZ
    go with the 10 bolt up front... axle shafts are cheaper and easyer to fined than a dana 44.
  5. tree_entz
    tree_entz 1/2 ton status
    May 4, 2004
    141
    N. Vermont
    all very true,
    but one thing that got me (i DID read this before) was the axle tube dia, and if I remember it was thicker on the 44.
    I believe there is also a ring gear difference of an inch?:thinking:
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Use a 10 bolt
  7. Dilbert73
    May 14, 2003
    19
    Fresno, CA
    OK, it's starting to make sense.
    Any significant strength differences between the two? Other reasons to go with one over the other? Years to look for/avoid with the 10 bolt?
  8. Dilbert73
    May 14, 2003
    19
    Fresno, CA
    Oops...too slow with my questions.
  9. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    The only real thing that the D44 has over the 10b is there are more aftermarket parts for them since they were used in many other different vehicle, the 10b is alot easier to find and you can swap on a set of D44 knuckles and be ready for crossover. :D
  10. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    85mudblazin beat me to it but i was going to say the d44 is easier to do crossover steering on
  11. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The D44 is only better for crossover steering if it came with flattop knuckles. Other then this advantage and the aftermarket advantage a 10 bolt wins in my opinion.
    Parts are cheaper and easier to come by. Parts are newer and have had less of there fatigue live used up.
    Harley
