10 bolt what splines?
Discussion in 'The Garage' started by skidpan, Mar 30, 2006.
  1. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    I have a 78 k10 it had a 12 bolt rear and still has the 10 bolt front. The 14 bolt i am going to be putting in this weekend has 4.56 gear ratio. I am looking for a 4.56 for the front. does it matter what axles I have? does 28 30 33 matter? what ones were in the 1/2 ton trucks? Also do you guys know of a good place to get a 4.56 for the front for cheap?
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You should have 28 spline axles in a 78 10 bolt.
    Try Randys ring and pinion for the gears.
    If you want cheaper gears try Ebay
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    What Tunder said . And you don't need a new carrier either , yours will work with 4.56 gears . Doesn't matter what splines as far as gears go . While its apart is a good time to add a locker :thumb:
