10 bolt
Discussion in 'The Garage' started by sunnyc123abc, Aug 28, 2005.
  1. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    Well after reading the threads about the 10 bolt's strenght, i decided to keep it for now. so im planning on buying new gears for it, probably 4.56. I was just wondering if i would be able to install it myself or do i need to get a shop to do it. And also, if i should buy the kit with new bearings and all, or just the ring and pinion. Also if u guys can please give me some tips and stuff, things i should know before i do this, that would be nice. thanks
    - sunny
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    10 bolts and strength? in the same sentence? :dunno:
    :doah:
  3. chevyk5blazer666
    chevyk5blazer666 Registered Member
    Jul 6, 2005
    44
    N.J.
    if you have a stock ten bolt then you prolly have 3.08 gears,i have the 10 bolt in my truck, and i never had any problems with it. and i beat the he** out of my truck. that's with 35 . i put 3.73's in mine and i did it my self .you just haft to make sure that you get the shims lined up and the back lashing correct
  4. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    cool...should i replace the bearings and stuff or just the gears itself.
  5. chevyk5blazer666
    Jul 6, 2005
    44
    N.J.
    id just replace the bearings to its worth the extra $20 dollars
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Do it right the first time. Have a knowledgeable tech install your gears with new bearings. Gears are not something that you can just do in your driveway with basic tools. You need a couple special tools and some know how to do it right.
    Harley
  7. chevyk5blazer666
    Jul 6, 2005
    44
    N.J.
    i did mine in my driveway
