10 bolt
Discussion in 'The Garage' started by sunnyc123abc, Sep 22, 2005.
  1. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    I have a stock 84 blazer, just wondering if the 10 bolt is a 8.5 or 8.2..thanxs
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    :doah: beat me to it. 8.5"
  4. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    thanxs...also if im installing new gears, what would be the reason for me to put in a spacers
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Different ranges of gears used different carriers for the ring gear. (I don't know what they are in a 10 bolt) Some of them are thicker than others. A spacer would allow you to run a "thin" carrier with a set of gears designed for a "thick" carrier.
  6. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Not to try to butt into your buisness but what are you regearing to? If you not going lower than 4.11 then there are alot of people that will sell you complete 10 bolts for cheaper that the gears new.
  7. sunnyc123abc
    Mar 12, 2005
    636
    SoCal
    im planning on 4.56, wouldn't shipping be alot for an axle?
