10 bolt ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mgaul, Jun 4, 2001.
  1. mgaul
    mgaul Newbie
    May 7, 2001
    Colorado
    I am putting a detroit true-trac in my front diff and need some helpful advice as to how to get the carriage out. I am told I need a diff spreader. I bet someone out there has a creative way of doing this.
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I didn't need a case spreader to put my Lock-Right in my 10 bolt. To remove the carrier I just used a long brass punch (because it's soft metal) to pry it out. And it actually didn't take that much prying. Maybe I just lucked out though.
  3. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    I had a friend help me with two pry bars. I know of quite a few who do it this way, but don't recommend it. I have since had a spreader home made from two steel bars and broken vice screw mechanism. Works good and several uses as any spreader.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  4. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    A Detroit true-trac replaces the carrier completely, does it not? (Just as would a regular Detroit locker, where with a Lockright, you would re-use the carrier.) You do know that you have to reset the backlash between the R&P when you change the carrier, right? For all but the greatest howler monkey's (aka orangutans) (ref: http://www.bc4x4.com/features/1999/sthm/sthm.cfm), that means work done by a shop.
    --Rob
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Look into what you are getting into, but to answer your question...... You dont need no stinking spreader....Putting the rubber end of a hammer up under the carrier and pushing down real hard on the head will bring it out. Just dont loosen the carrier bearing cap bolts all the way till you get it loose. That thing is heavy to catch on the fly....[​IMG]
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
