10 BOLTS AND 35s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85 4x4 shortbed, May 15, 2003.
  1. 85 4x4 shortbed
    85 4x4 shortbed Registered Member
    Apr 7, 2003
    20
    Anyone run 35x12.5x15s on 10 bolts? Ive noticed a lot of guys here running them here.
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    ????... out of the thousands of people on ck5, im sure some run that.
  3. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I was running a rear 10 bolt on 35's for awhile. Then I blew the Gov-Loc up. Now im running a 6-Lug 14 bolt Semi-Floater.
  4. getitup
    getitup Registered Member
    Apr 27, 2003
    35
    Hazelwood, MO
    Everyone I know with 10 bolts run 36 TSLs and they havent broke the 10 bolts yet. Just the u-joints but I have done that with my 31 ATs. So I would say go for the 35s
  5. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    I used to have 10b + 35x12.5x15s. Worked well, my 10 bolts were built tho. full floating kit, chrome moly shafts, the whole nine yards. IMO, the 10bolt front axle is workable with pretty big tires (i dunno, maybe 37s?) but the 10b rear is pretty much junk, mainly because its semi-floating.
    If ur rich, just go d60/ff14b. If ur poor, a beefed 10b front and a semi floating 14b rear would be a good option. You'd get to keep ur 6 lug wheels, and the sf14b, while still semi floating... is quite a bit stronger than the lowly 10b rear.
    j
  6. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I stil have 10bolts in mine with 35x15.50x15s, 4.56s and front and rear lockers. I keep saying one of these days i will change them out.
  7. zcarczar
    Feb 10, 2002
    2,495
    I think the weakest part of a stock 10 bolt rear end is the stock carrier. Out of all the rear diff's ive seen broken its almost always been carrier related. Thats why I say if your never going to go bigger than 35's throw an aftermarket carrier in the back and carry some spare shafts and go play away.
  8. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i have been running 35'son my 10 bolts for about a year without a problem , except for the driveshaft joint , but
    thats an angle issue.
    i am looking a 14bff, so i can have better wheeling
    security.
  9. Jaguargt
    Jaguargt Registered Member
    Mar 14, 2003
    46
    Guatemala
    Could be a problem running 35's, 10 bolt, stock gear and a 700R4?,
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Like mentioned above one of the main weaknesses is the spider gears and or govlock differential. I personally broke my govlock on the street with 32's and a stockish 350.
    I had it replaced with an Auburn full case posi after that and never had a problems with the 32's and the 10 bolt again. I never was really "hardcore" on it though. Mild to moderate wheeling. If you had a good set of gears and a full case locker or posi then a 10 bolt isn't really that bad. You better carry spare parts because you might need them, but it can survive with a good driving technique.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I thrash my 10 bolt front/14 bolt SF rear (8 lug) and have no problems running 35s.
  12. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ya, I am still running the 10 bolt front. I did upgrade the rear to 14bff. The front is now locked and on 35's so now I need to get some wheeling in on it and see how it holds up. But some of the AZ guys run 1/2 front and rear with 35's and beat the ever loving piss out of them. They do brake parts, but not as often as most would think they would.
  13. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Question... </font>
    <font color="green"> Answer... </font>
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  14. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    I used to run open 10 bolts in the front of mine all the time, in fact only one of my 4wheeling crowd that did. I ran 35's for 3 years with no problems then went up to a 38.5 tsl then back down to a 36 which it stayed that way for 2 years. I say 35's and a 10 bolt will be fine, just make sure your front and rear gears match (thats a big duh but seen people overlook it lots).
  15. Jaguargt
    Mar 14, 2003
    46
    Guatemala
    but it's exist the risk of overheating the 700R4 with 35's and stock gears?
  16. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    If your stock gears are 3.08 it is for sure a bad combination. For 35's you need minimum 4.10 gears to keep the engine and tranny in the RPM range where it's supposed to be working.
  17. wadinator
    wadinator 1/2 ton status
    Dec 18, 2001
    233
    NW Iowa
    DEFINITELY! If your 700r4 tranny is an 85 model, they already are prone to failure. If you try running 35's and stock gearing with that tranny, you might as well start saving your pennies for a new one now. /forums/images/graemlins/1zhelp.gif
  18. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Just don't run in OD if you have crap gearing and a 700R4. Run in D all the time unless you are doing 75+ on a flat stretch of highway.
  19. wadinator
    Dec 18, 2001
    233
    NW Iowa
    Good point. /forums/images/graemlins/thumb.gif
  20. Jaguargt
    Mar 14, 2003
    46
    Guatemala
    Good tip, thanx.
