10 bolts are garbage, GRRRR...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Silver84k5, Feb 13, 2002.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Was out in central oregon wheeling, tried to climb a few boulders, and all i hear is BANG.... then we pull my truck off the rocks and i look at my rear tire, its sticking out of wheel well about 2 feet, then i find my front driveline about 10 feet away from my truck, then when i went back to the cabin to get some help, i come back and my damn CD player got stolen, i was 200 miles from home heh, How much stronger is a 12 bolt then a 10 bolt, cuz i had an extra 12 bolt from my 77 that i had my friend bring me, just curious how much more strength i have (if any)
    If you dont make it the first time, Drink another beer, and press a little harder on the gas
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    If you wanna keep the 6 lugs, get the 14 bolt SEMI-floater instead. It's even more stronger than the 12 bolt. [​IMG]
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i got a 14ff ready to go in, im just waiting on the money for Rims, and new 42"s, but who knows how long that will take, im just curious about that 12, i dont want to get caught in the damn woods again i almost didnt make it to work on monday
  4. lgk5
    lgk5 1/2 ton status
    Apr 3, 2001
    269
    slc,ut.u.s.a
    is there a dent on the floor board right under the gas pedal?
  5. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i dont think so i havent really loooked
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    A 12 bolt is a little stronger than a 10, and won't take much time to slide in there until you are ready for the 14
    90K5
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    heh its already in there, i had to change it in the hills where i broke the other one, so i could get home
  8. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    The 12 bolt is a little stronger. It has a 8.875" ring gear where the 10 bolt is 8.5". The axle shaft legnth is the same, the only differnece I have ever found in the axle shafts is where they spline into the carrier. They look almost the same but the 12 bolt is a little thicker. To make a long story short the 12 bolt is a little stronger but you will be very happy when you get your 14 bolt installed. I know I was.
    '80 K10 350/350/NP205/14B/10B/4.10/4"Lift/Q78-Buckshots
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    this kind of comment is ridiculous
    so one is supposed to take a high torque V8 engine but only idle around?
    the loud pedal SHOULD be on the floor
    now if he was hopping real bad and broke something you can defend the driver error claim.
    even then the tiny ujoints should pop before hard axle parts.
    formerly 77chev
    still a jerk though
  10. lgk5
    lgk5 1/2 ton status
    Apr 3, 2001
    269
    slc,ut.u.s.a
    it was ment as a joke after i read his sig but next time i'll be
    more careful ofYOUR feelings
  11. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    12 bolt 8.7/8 ring gear 1.31 axel shaft diameter 30 spline.
    10 bolt 8.5 ring gear 1.28 axel shaft diameter 28 spline.
    Corey 78K5
    350CI, TH350, 203, Dana 44,12 Bolt, 4"lift, Shackel Flip, Sawsall and 35" BFG's
  12. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    sorry just hear that all the time
    formerly 77chev
    still a jerk though
  13. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Just be aware that in your situation, it doesn't sound like the ring gear was the problem in your 10-bolt. It was the axle shaft itself. 12-bolt axle shafts are a little bit larger than 10-bolts, but not much. And they are still c-clips. So, if the shaft were to break again on the 12-bolt, you will end up in the same situation. The 14BFF will help you here as if a shaft breaks, your wheel won't depart the housing. You could at least be able to limp home on it.
    I'm sorry to hear you had this kind of luck. But, anything is breakable. DBLAZER has broken 2 Dana 60 stub shafts crawling on relatively simple stuff here in Texas. It just goes to show that ANY part can be broken.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  14. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    hey where is DBLAZER at? i havent seen him lurking around the boards lately...
    Later
    Just tap it in...tappity tap tap...
  15. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    He's kinda disappeared. He and his wife really got into everything (rig, club, etc) and forgot to take time for themselves. They resigned from the committee in our club a little while back (couple months or so) and have since left the club. They have kinda disappeared. I here for personal reasons (whatever that means).
    Last I heard, however, is that he is putting 2.5 ton rockwells under his rig and chopping it up BIG TIME. Won't be much of a way to even tell it was a K5 when he gets done with it.
    Brian
  16. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    So sensitive
    "What ever happened to my Rock N Roll?"
  17. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    hey man i understand...i guess they are taking a little "break" from things?? thats cool...rockwells would be bad a$$!!!!!
    i was wondering what happened i mean he gets his pic in magazines and stuff and then its like he falls off the face of the earth...
    oh well let him know we wanna see his rig when its done...
    Later
  18. 2BLAZERS
    2BLAZERS 1/2 ton status Premium Member
    Oct 12, 2001
    513
    4
    KEIZER, OR
    What size and type of tires were you running when this happened?
  19. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    38" 15.50 Tsl Swamps,
  20. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your 12 bolt will probably not last long with those tires. I would get a 14bolt full floater if you want to run tires that size. A dana 60 front would be a good idea too.
    My Chevy isn't broken, its just out of gas.
