10 foot army whip
Discussion in 'Communication (CB | GPS | HAM)' started by tacomuncher, Feb 14, 2006.
  1. tacomuncher
    tacomuncher 1/2 ton status
    Jan 3, 2006
    110
    goleta ca
    i got a big army whip i riged it all up but it dosnt get the rang that i though it would dose anyone know of anything that coulg help the range out.
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Not designed for 11 meter (CB). I'd check those SWR's and see if you're burning up your radio.
  3. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    It's either for 6 meters or 12 meters, unless there's a loading coil on the end. 6 Meters sounds about right though, 50 Mhz VHF
  4. tacomuncher
    Jan 3, 2006
    110
    goleta ca
    what are the loading coil all about? and the meters im a dumb ass tell me more
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    CB is 11 meter. 6 meter and 12 meter are different freq range. Trying too use a 6 meter antenna with a 11 meter radio you'll burning up your radio because of high SWR's.
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I always thought good range was accomplished with POWER,,,
    lots of it:D
    have a 250w linear for my Cobra radio, did real nice "down the range":D
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Power can be a good thing sometimes, but you have too match your antenna to your radio. I've ran a linar amp or two in my time, and I'm sure I'll run another one sooner or later, but like I said, you must use equipment that are designed too work together. In this case, a 6 meter antenna with a 11 meter radio will cause high SWR's and burn up the finals in the 11 meter radio.
  8. 4xcrazy
    Oct 31, 2003
    9,472
    5
    I don't disagree with you at all on that,,,just goofin about the "long range" thing,,,
    MORE POWER,,,ARGH ARGH ARGH :haha:
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd have too go with modulation over plain power. Put some swing in that thang !!!!!
  10. 4xcrazy
    Oct 31, 2003
    9,472
    5
    fixed it for ya :D
  11. tacomuncher
    Jan 3, 2006
    110
    goleta ca
    :D thank u for the help i use it today out on some hills and i got some ok range. i haven't changed anything. i ran into a army officer at a radioshack who had a active cucv m1009 blazer with a crap load of antenas on it and he said something about a unit that u could use to boost the signal he didn't know what it was called but im sure ill figure it out.
  12. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    A linar maybe ??? I'm telling you, you need too check the SWR's !!!!!! If that antenna is as off as I think it is, your SWR's will be through the roof. High SWR's can damage your radio.
  13. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
    what antenna? what base?
    i ran a mx6707 and ms116 shaft. gutted the base, trimmed the antenna and ran 1.2swr's
