10" rims with 35's and a 4" lift?
Discussion in 'The Garage' started by bigarmzz, Sep 24, 2006.
  1. bigarmzz
    bigarmzz 1/2 ton status
    Feb 21, 2005
    184
    elkins, west virginia
    i'll try this again since the site was f**ked up for a few days-
    will 10" rims fit on a 4" lift with 35's without cutting the fenders?
    i've always ran 8" rims before with this combo without any problems, but like the look of the wider rims
    any of ya'all have pics of this without cutting?
  2. bigarmzz
    Feb 21, 2005
    184
    bump (since the other posts were deleted)
    thanks;)
  3. k2mslskier
    k2mslskier 1/2 ton status
    Feb 18, 2005
    1,524
    Tucson, AZ
    4", 35's, 15x10's...no rubbing...no trimming...yet. I have smacked the back of my right front fender but that was only during some hard playing in the mud, hit a rut that I couldn't see.
  4. bigarmzz
    Feb 21, 2005
    184
    man that looks badass:bow:
    from what i've been hearing, the 10's stick out from the fenders, but they dont look they do on your rig at all....def, looks good:D
  5. 81K5GUY
    81K5GUY 1/2 ton status
    Jan 30, 2006
    943
    Rockingham ,N.C.
    whats the backspacing on those rims?
  6. k2mslskier
    Feb 18, 2005
    1,524
    Tucson, AZ
    This may sound stupid but honestly I'm not sure. I ordered them from Summit and told them what they were going on and they sent them. My guess would be 4.25". The front sticks out just a tad more than the back but that is normal for a Chevy as we all know.
    Edit: Just pulled up the receipt. Part #MTT-350411, if that helps. And it's an 86 by the way.
  7. bigarmzz
    Feb 21, 2005
    184
  8. k2mslskier
    Feb 18, 2005
    1,524
    Tucson, AZ
    My guess was way off.:D
  9. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    If you got flex you will rub with 10" rims, at least mine did.
  10. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    I just wheeled last weekend. 4" lift 35's on stock 15X8 wheels, no sway bar, uncut fenders(for now) and I cut up my front tires pretty bad, Ill try and get a pic tomorrow when there is daylight.
  11. 81K5GUY
    Jan 30, 2006
    943
    Rockingham ,N.C.
    sweet rig.Thanks for the info.Im about to do the same thing but had been worrying about getting the right rims
  12. roadhawg
    roadhawg 1/2 ton status
    Aug 15, 2003
    495
    Oregon
    4" lift with 35x10. I am thinking 3.5 to 4 inch backspacing. it does rub when flexing and i have cut one of the tires slightly in a bind.....It needs to be trimmed but im scared.
  13. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Don't be sceered... it gives it a nice spartain look if the cuts are jagged :D Your avitar is freakin hilarious :bow:
  14. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    here's mine 4" lift rough country, 15x 10 rims with 4.25" backspacing
    and 35 x 12.50 x 15 m/t's
  15. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I had Eagle 589s on mine with 35 15.5 15 MT Baja HPs on them and I would rub a little on the rear of the front fender when flexing a lot. It wasn't enough for me to trim or worry about though.
    Can't get the other pics to resize so hopefully this one is good enough
  16. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I've got 35s on 15x10 rims with a 4in lift and 2.5in body lift. I have never had a problem with rubbing at all. Even at full flex with my flexy 52s.
  17. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If you have any flex at all it will rub. Nothing that cant be fixed with a hammer and saw though.
  18. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i used to have 3" and 35bfg's on 15x10's and it would rub a good bit.
  19. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Here's 4" with 35's on 15x10's.
