10 spline 465 failure?
Discussion in 'The Garage' started by KevinsK5, May 16, 2006.
  1. KevinsK5
    KevinsK5 1/2 ton status Premium Member
    Jan 17, 2005
    257
    13
    Golden, CO
    Ever heard of the output/coupler/input failing completely on a 10 spline 465-205? Heard they wear out and get sloppy, but complete failure? :dunno: Thanks, Kevin
  2. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    yes I have a Coupler in 7 pieces to prove it
  3. yellowK20
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    oh and Mountain explorer just broke one also
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Well we wouldn't care that they wore out if it didn't mean failure. That's why 32 spline is better. 10-spline wears and fails. But all of mine are in good shape.:D
  5. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    I've got two laying around if ya need a replacement.
  6. goldwing2000
    goldwing2000 Guest
    Yeah, if the coupler doesn't stay well-lubricated, it dries out, rusts out, wears out and either spins the splines out or just shatters.
  7. KevinsK5
    Jan 17, 2005
    257
    13
    Golden, CO
    Is there a beefy 10 spline coupler available in the aftermarket? Thanks, Kevin
  8. redneck396
    redneck396 Registered Member
    May 17, 2006
    10
    Riverton, WY
    Oh I have personally destroyed one to the extent that the biggest piece was the size of a nickel!!!
  9. goldwing2000
    goldwing2000 Guest
    If they make it any beefier, it won't fit inside the adapter. Just make sure it stays lubricated and you should be fine.
    Personally, I never had a problem with mine.
  10. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    Just use the 32 spline version. That is the upgrade.
  11. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    So once one goes does it take the tranny output shaft and t-case input shaft with it??
  12. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Not necessarily.
  13. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Not from what I've seen.
    I have the SM465/Rockwell T221 that was originally in my truck, and the sleeve was worn down almost smooth inside. I have a SM465/205 combo, and the splines are worn about 1/2 way through, and the edges are SHARP. I have a 2nd 465/205 combo that appears brand new, the guy who gave it to me said it came out of a brush fire truck that had less than 10,000 miles when it caught on fire and was totaled.
    On all 3 of these setups, the transfer case input gear still looks brand new. Only the sleeve and the output shaft of the 465 are fubared.
    I wanted to upgrade to the 32 spline, but GOOD LUCK finding one. Only used in 1985-1991 K30/V30(3500).
    So...I am now going with a divorced t-case. :p:
