10 to 12 bolt interchangeability?????
Discussion in 'The Garage' started by Supreme70, Nov 29, 2005.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    I'm wondering if you can swap the rear backing plate with the wheel cynlinder on it, form a 87 10 bolt to a 84 12 bolt, and does the drums interchange as well, was also wondering if the axle seals are interchangeable too. :dunno:
    PLEASE HELP!!!!!!
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have 83 10 bolt brakes , backing plates and all , on a 70's 12 bolt :D
    The difference is in the center section and axle spline .
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    An '84 12 bolt?
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    no such animal. 12 bolts were phased out in 1981.
  5. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    I got a set of axels and the guy said they were from a 84, now I know better. so the backing plates will work, what about the axel seals.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Should be no problem on the seals . I stuck 30 spline 10 bolt axles in a 12 bolt for a month ( with material welded on the end to make right length to the crosshaft ) while waiting on 12 bolt axles , and no leaks or anything .
  7. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    so are the 12 bolts stronger or the same as 10 bolts as far as strength.
  8. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    they have a couple MARGINAL strength differences...not really worth talking about...in all honesty, they are just about the same strength overall.
