$1000 350 rebuild?
Discussion in 'The Garage' started by bigbadchev84, Oct 25, 2006.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    hey guys im needing suggestions as to if it is even possible to do this:
    My buddy has a 1980 crew cab 350/465/205 60/14b with 4.56 gears and some metric 32" tires, He mainly uses this to tow his 28' camp trailer and his utility trailer. his current motor is getting tired and has problems pulling grades above 50mph and he complains of no power in 4th.
    I gave him a 350 out of a 76' that i junked, it runs, but has low oil pressure-5psi when warm 25 when cold and it smokes a bit, he is wanting to rebuild it. is it posible to do this with $1000? if so what combos should we look at? i told him to spend the $1400.00 to get the 290hp gm crate, but he thinks he can build a better motor with more hp for that price? Is it doable or is he drinking his bathwater?
  2. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Easily do-able. You could probably decently rebuild a 350 for $500.
  3. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    its possible
    but when he gets thru is it going to have the 36/50,000 mile warranty that the 290 hp gm crate motor will have?:wink1:
  4. OrangeCrushK10
    Jan 25, 2003
    1,425
    very true
  5. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I paid about $900 for a totally rebuilt 350 with a new crank and the heads completely rebuilt. The build did not come with any high performance parts at all just your average oem equivalent but it does have flat top pistions.
    It has a 12 month 12k warranty which will have expired by the time I get the damn thing on the trail!
  6. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    :haha:
    just out of curiosity, where are yall taking your motors to be rebuilt at these prices? rod shops? machine shops?
  7. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    i was figuring about 5-600 just in machine shop to geth the heads, cam bearings, bore and balance
  8. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    I called a reputable shop in my town and told them what I wanted. I just had the basic rebuild done with their parts. They gave me reconditioned connecting rods and oem valves. The heads I had were loaded with some outrageously heavy springs so they put in oem springs too.
    So far I have broke the motor in and it runs fine.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    FWIW, that only applies to engines that are speced out for that vehicle. if the truck happens to call for the 290 hp GMPP engine, then the 36/50,000 warranty would work. it also has to be installed by a reputable shop IIRC.
  10. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i did one for my own truck in '99, reconditioned the heads, bore and hone, tank and crack check everything, align hone, checked the rods out myself, they were ok, reconditioned crank, new pistons, rings, bearings, cam and lifters and i did all the assembly work myself for $800.
  11. SLOK5
    SLOK5 1/2 ton status
    Apr 25, 2005
    216
    SAN LUIS OBISPO CA
    New or remanufactured GM Engines are designed to meet or exceed your requirements! These auto engines and parts are tested to make sure they’ll perform under the most demanding conditions and backed by a 36-month/100,000 mile nationwide limited warranty (parts & labor).
    Engines designed for OEM warranty replacement use only GM authorized replacement parts. Engines for older vehicles are optimized for best performance value and price. Design enhancements and product improvements are incorporated into some remanufactured car or truck engines.
    Plus, service is available at nearly 7,000 GM dealers across the United States and Canada.
  12. 02turbogixxer
    02turbogixxer Registered Member
    Aug 1, 2006
    63
    Dallas, TX
    I think blazin_blazer was suggesting that if he built the motor himself he wouldn't get the 36/100,000 mile warranty that he would get if he went the the 290 hp GM create motor.
  13. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the 290 hp engine doesnt come with anything remotely close to a 36/100000 warranty. its 12/12000
  14. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i took a running 350 and rebuilt it and it cost me about $300 total. i bought the kit from northern auto parts and took my heads and block to the local shop for valve job and jetwash the block for $110. is probably the most reliable/most power engine i have for the money i have into it.
  15. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    FWIW...
    http://www.sdpc2000.com/catalog/120/products/228960/290HP-350-Long-Block-Pre-Emissions-GM-Crate-Engine.htm
  16. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    i have a place saved to my favorites at work that has rebuilt longblocks with a 5yr/100,000 warranty, and it doesn't matter who installs the engine. i will post a link to this place tomorrow. i have a friend who bought a 454 longblock from them and then got the rest of the stuff he needed from summit and swapped his 84 k10 over to a big block, its been about 4 months and no trouble yet.
  17. JohnDeere
    JohnDeere 1/2 ton status
    Jan 17, 2006
    342
    Houston, Texas
    Sorry for the highjack but in about a year or so im going to do a 454 swap in my k5 i can pick up a running 454 for 600 with tbi but no harness or computer. I talked to a local shop i they said they could rebuild it for about $1000 to $1400 depending on what i wanted with a 1/10,000 warranty. I think he said for a 383 stroker it would be about $900 buck, but which would be the better route?
  18. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
  19. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    A budget rebuild could be easily done for under a grand if you're doing the work yourself. I would suggest putting some good heads on it, Vortecs work well, and putting a larger cam in it, with the 4.56's and 32's that motor is going to spin some R's on the highway, get a cam that will put the powerband where you want it. That GM 350 is a good motor too, I would again suggest a larger cam if you go that route. Stock cams are anemic. A set of headers and good exhaust would help too, if not already equipped.
  20. OrangeCrushK10
    Jan 25, 2003
    1,425
    After working in an install place I know why they do this and how it works.
    Because 90% of the time, if the engine fails they will pin it on the install. That is unless you have ALL the proper documentation and can prove to them without a doubt that it was their fault..... but even then it is up to their "lab" to determine if it was their fault.
    On top of that it will normally take them about a year or so to get you your cash from the warranty.
