102" stainless whip mount ideas?
Discussion in 'Communication (CB | GPS | HAM)' started by **DONOTDELETE**, Oct 30, 2001.
    102\" stainless whip mount ideas?
    I would like to mount my 102" stainless whip on the rear bumper, but I would like to see other member's pics of how they mounted their CB antenna. Should I just mount it directly to the top of the factory chrome bumper.
    Thanks,
    Doug
    4 wheelin's not a job, it's an adventure!
  1. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: 102\" stainless whip mount ideas?
    My 102 inch whip is mounted on a shelf in the garage. [​IMG] I got tired of it whipping the crap out of my truck on 4WD trails and installed a short fiberglass antenna instead. [​IMG]
  2. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    I have mine mounted on the drivers side of the rear bumper(stock) I will see about getting a pic on tonight maybe. It does whip around a bit and it can get annoying.
    Brian
    83 K-5 4" on 35's
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    mine is mounted on the passenger front bumper i only use it when i go to the sand dunes though and a 5' fiberglass on the trails
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  4. bowtie4466
    bowtie4466 Registered Member
    Apr 30, 2000
    13
    I mounted my whip on the passenger side rear bumper. I used a "L" shaped antenna mount bracket from Radio Shack and just bolted it directly to the bumper. I bolted it onto the side part after it curves around, so its technically on the side. It rarely ever hits the blazer itself, but it does hit everything else. I can't complain though. Let me know if you want to see a picture - I might have one.
  5. Re: 102
    I mounted mine on the passenger side on the rear (after it curves around) and also used the mount from Radio Shack. I drilled the mounting holes through the black rubber on the bumper to get the mount farther away from the body. One thing I added is a coil spring (Radio Shack) that sits between the mount and the antenna. It gives it flex and helps keep the antenna from getting bent. It has never hit the body of the truck! I use a 102" when out in the woods and a shorter one around town. I have some pictures if you're interested.
  6. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    Re: 102
    can i have a pic and how much did all that cost and how much of a pain if any was it to install. i want a c.b. i'm looking at a good set up c.b that is fairly cheap if that is possible. and my email addy is k5ntexas@hotmail.com to send the pic if you would. thanx. later.
    jacob
    what is that low rider doing under my k5?
    wow nice lil jap car. whats it good for?
  7. Re: 102
    You should have the pics in your email.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'm planning on getting a roof light bar. I'm going to mount my 102 on it.
  9. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I hope your saying that in jest.
    But if your not I hope you live in a town with no street lights or power lines that run over the street.
    Eric
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Didn't have a problem with the one on my last Blazer. Could always tie it down if needed to.
  11. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    uhhh yeah you might wanna tie that down pretty low... I had my 100" whip mounted on the rear panel, about 6 inches down from the bottom of the top... Don't know how high up the top was, but without it tied down it whacked trees all over the place, but it does make a cool sound when the antenna slides over the light covers at the McD's and bank drive throughs /forums/images/icons/tongue.gif
  12. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I always put the 102" on a pot-belly spring. It seems that the more you wack them on things, the better they work.
