10b...28spline insides in a 30spline?
Discussion in 'The Garage' started by muddybuddy, Dec 12, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey there, ive got all the gears spiders and carrier from a 28spline 10b. will they work in the newer 30 spline 10bolts? im pretty sure they will, since i have a new in box carrier and it says its for 28/30 spline. ??
  2. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    You can put 30s in a 28 so I dont see why you can't go the other way.
  3. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    The 10 bolt housings are the same. So as long as you use a 28 spline carrier, side gears, spiders and your 28 spline shafts you should be fine. I took the 28s out of my 10 bolt and replaced it all with 30 spline stuff.
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    weird, the new carrier that i have in the box,says on the outside that wills for 28/30 spline 10b's????
  5. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    When I put the 30spline carrier in my truck I found out that the carrier bearings are larger than the 28 splines.
  6. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    so then in order to run the carrier the 28 shafts would be needed
  7. 6.2puller
    Jul 8, 2004
    569
    New England
    It has been a few years but I thought I just swapped side gears and spiders then the 30 spline shafts fit in the 28 spline carrier/housing. :confused:
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    My understanding was that you could not put 30-spline side gears into a 28-spline carrier (though they fit) because the area that the shafts slide into the carrier were not big enough for the larger 30-spline shafts to slide in to.........hence the need for bigger carrier bearings. If you had a 30-spline carrier than I would guess it could be converted to 28-spline.
    If you are swapping out entire carrier assemblies then it doesn't matter as long as you have the right carrier bearings, and obviously the correct shafts.
  9. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    A 28 spline carrier WILL NOT work with 30 spline axles. Been there, tried that.
    John
  10. 6.2puller
    Jul 8, 2004
    569
    New England
    Your right. I had to hog out the inside with the lathe by about .050" or so to get the larger shaft through. Like I said it has been a few years. ( about 8 I think)
