10b 8 lug conversion parts
Discussion in 'Parts & Trucks Wanted' started by SkulzNBonz, Feb 25, 2006.
  1. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Looking for all the pieces necessary to convert my 6 lug front to 8 lug. Thanks.
    John
  2. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Got it, how much do you wanna spend??
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Do you really want an answer to that? :haha: No one ever WANTS to spend money...
  5. AlphaMale
    AlphaMale Registered Member
    Sep 6, 2005
    63
    Las Vegas
    i've got some 10 bolt 8 lug hub's and rotors. you will need to find some spindles and backing plates....althought i belive that the 6 lug and 8 lug spindles and backing plates are the same. You can also convert a dana 44 6 lug to an 8 lug using the 10 bolt 8 lug hubs, spindles, bearing and backing plate.
  6. sweetk30
    Nov 1, 2004
    25,549
    543
    spindles same plates no. 3/4 ton 1" bigger rotor so plate is bigger.
  7. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    Spindle's are the same as long as they are the big bearing units,but the backing plates are bigger in diameter for the 8 lug.I have the stuff as well.
  8. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    PM sent. Thanks.
    John
  9. Danny Joe
    Danny Joe 1/2 ton status
    Feb 10, 2005
    134
    Blythe,California
    I found a guy that will sell you the whole setup for a couple hundred bucks! Call me at 760-899-5694 and i'll give you his number.
  10. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Educate me. What all do I need? Spindles, rotors, and backing plates, right? TIA.
    John
  11. 1-tonmudder
    Apr 24, 2005
    3,052
    if you are converting a 10 bolt all you will need is a set of big bearing hubs/rotors and backing plates(which are on all 10 bolt front and 76 or so up Dana 44's).The spindles,calipers,pads and even the wheel bearing's are the same.
    If you are converting a 72-76 or so Dana 44 you will probably need a set of small bearing hubs and spindles and the 8 lug backing plates.Everything else is the same.Despite what alot of people say there is a difference in the 6 lug and 8 lug backing plates.
    The first lesson is free.:D :D
  12. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    It's a '89 front end, so I need the hubs/rotors & backing plates, which you have, so I'm good to go with our deal?
    John
