10B Diff Rock Guard or SkidPlate
Discussion in 'The Garage' started by 88Silverado, Jul 5, 2004.
  1. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    After banging my front 4-5 times this weekend and one nice drop on a rock where it scraped across the bottom and across the u-joint and front shaft, im looking for opinions on guards or skdplates. Seems a plate would protect both sides of the diff where the guard only the front. Any thoughts and who makes a reasonably priced one?
    Maybe even one for the rear?
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I'm thinking about doing the opposite... 2" wide 3/8" plate in the middle over teh ring gear and skeleton of rod on the sides /forums/images/graemlins/thinking.gif
  3. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I just run a stock style chrome front cover, thats pretty thick and no sort of u-joint protection, while, my d-shaft, u-joint and yoke has taken a beating it is still fine with no skidplate and I am by no means easy on it.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Most stock 10 bolt front covers are pretty thick. I ran a 1/4" plate that is about 2" wide down the front of the diff over the ring gear. That is all I did for protection to the 10 bolt front. With that plate welded on that cover is pretty beef.
    I personally wouldn't run a skidplate. It is just something that will take away ground clearence. The housing itself should take quite a beating without the need for a skid plate.
    The best cure for the driveshaft and ujoint hits is a good spotter to keep you off them. There is no good way that I know of to protect them. Nobody I know here in AZ runs one and they do ALOT of rocks.
    Get yourself a diff cage or beef up the stock cover and call it good.
    Harley
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I have one of those skid plate things that bolts to the axle tube, its kinda big, but you can have it. At least use it to make a differrent protector.
