10b front, 14bff rear....steelies?
Discussion in 'The Garage' started by socal chevy, Apr 13, 2005.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    I have my stock 10b in front and am installing a 14bff in the rear with disc brakes.... Will I have any clearance problems with 15's? If so... where? What backspacing should i get?... What width wheel?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm running a D44/14ff with 15 x 8's with 2.75 BS and rear discs, no caliper grinding for me :D
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Narrower wheels will take less grinding. Less BS will take less grinding. I am running 15x8" steelies with 4" of BS. I had to grind a fair amount to get it to clear. Nothing I am worried about safety wise just it took awhile.
    Back Spacing can be your friend and your enemy. It will take less grinding to clear the brakes but it will also add extra strain to the ball joints. It will also make your truck wider which may be a positive or a negative depending on your wheeling environment.
    If you offroad hard with 2.75" BS rims on a 10 bolt front you will be playing the balljoint game alot. Friends of mine that run that setup can go threw ball joints in as little as 2-3 months depending on the amount of wheeling they get in.
    I have run 4" BS with my 10 bolt front for 1 year of hard wheeling and my balljoints are still tight.
    If you don't wheel hard or don't mind the balljoint game then 2.75" BS might be ok for you.
    Harley
  4. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
  5. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    I bought some 15x8 white spokes w4" bksp. and had them powdecoated black. Just got them back yesterday.
  6. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    got some pics installed?
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    My truck runs 15x8" rims with 4.125" BS. They are white steel wagon wheels painted black. There are numerous pics in my webshots linked below. I run a 14bff rear and 10 bolt front.
    Harley
  8. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,003
    826
    Pinckney, MI
    Lots and lots of grinding for me. I have the white spoke 15x10 with 4" Of backspacing. But anyways There going to get the rattle can soon... just dont like the white.
  9. gone huntin
    Oct 25, 2004
    1,706
    Coldwater, MS
    No, I've still gotta install the 14bff this weekend.
