10b front strength
Discussion in 'The Garage' started by TXsizeK5, Feb 5, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    If i put in a 14bolt rear with the 6lug conversion and kept my 10bolt front, how big tires could i run till i start negotiating the strength of the 10bolt... for daily driving? and for mudding? and for more extreme rock crawling, etc.
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    DD would last indefinetly since the front axle shouldn't be engaged except off road.
    Mudding - I'd say 36 to 38, if open. With locker - probably 35 maybe 36.
    Rocks - I can only go by what the guys on here say, but it looks like you're going to frag a ujoint and maybe a shaft every so often no matter what size you run, so bring spares.
    This is all my opinion only and others may have better ideas.
    -- Mike
  3. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    i dont do rocks... (none here or anywhere around for that matter) mud and trails i do.. i run 35's now, so if i upgraded to 37's i should be ok right? keeping it open ofcourse, MAYBE a posi.
  4. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Corpus, you're not that far from me. No rocks in Houston either.
    My opinion is that the 37s would work for mud use. No locker no posi open only.
    -- Mike
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You could probably get away with 37's. I have seen he guys in AZ run 35's with lockers on the rocks and they last pretty well. They know eventually they will break an axle shaft or ujoint though. It took TheRobZilla 2 years (or something like that) to break his first axle on the rocks with 35's and locker. You can do it, but have spare parts just incase. I am going to try and make 37's last on rocks with a locker one day, but I will probably have alloy front axles by then.
  6. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    i had no luck with my old 10 bolt front. maybe i had too much power /forums/images/graemlins/grin.gif
  7. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Ran 10-bolt locked front for quite some time on 35s. Never had a problem. You also just have to play it smart. Don't be cranking the wheel hard and punch it, you know?!? Many times, longevity of parts is as much what's above the pedal as what's below them.
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    What gears are you running and how heavy is your right foot? If you play it safe and are easy on the go pedal, I have seen a 10bolt last with 44's in the mud! As long as you use your head and keep everything in it in good shape and fresh, you'll be fine...
  9. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I made one lst with 38"s for years. I never beat it though.
  10. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I ran 35 Gumbos on 72 K5.Wore out one set,1/4 way through new ones 2 ton truck hit it head on while wife was using it.It died,wife was just shook up.Anyways only thing broke was couple u-joints.Really beat on it too_Open front,clutch poss on rear. /forums/images/graemlins/thumb.gif
  11. k5ntexas
    k5ntexas 1/2 ton status
    Oct 29, 2001
    2,517
    corpus christi, texas.
    hes got 4.56's. he doesn't have a hard right foot. hes a perty tame person when it comes to muddin. he can mud damn good too. later.
    jacob
  12. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    who makes a 6lug conversion for a 14bolt?
  13. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    Aw stop it. /forums/images/graemlins/blush.gif LoL
    As for who makes it. www.echobit.com
    They have a wheel spacer that "converts" 8-6 lug
  14. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    I have only broken 2 shafts on mine, one stub, and the short side. but i rock crawl, and don't rock crawl lightly /forums/images/graemlins/wink.gif
  15. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    reason im wondering is cause i was thinin of buyin that 10bolt off ya? no answer to my PM's?
