10B swap to 14B SF -- U-joint ?'s***UPDATE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83ZZ502_Jimmy, Mar 9, 2002.
  1. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    10B swap to 14B SF -- U-joint ?\'s***UPDATE
    A little background...
    I have completed the swap from a 10B to a 14B SF in the K5. I got all (brakes, axles, everything) hooked up. This is a six lug axle I have put together, orginally an 8 lug. This axle is from a 3/4 ton 4x4 1984-1988 Diesel Suburban. I am putting this into a 1987 K-5.
    Now...
    Everything has bolted up just great. After getting the brakes straight, I go to hook up the driveshaft...
    Now I checked this. It appeared ( also measured, not really well, but ) to be the same U-joint. But I find out it is not./forums/images/icons/mad.gif It is SOOOO close its not even funny. It almost fit into the yoke. It was a little wider but not by much. I ground just a tiny bit off the ears that hold it in. It goes in... I think I'm ok, but no. The joint on the K5 is too small, not width, but diameter of the caps. I happened to have one cap that was stuck in the axle when I scrounged it. It was a larger diameter than the caps on the K5.
    Does anyone has any input on this? Do I need a new driveshaft? If so, how soon can Jesse at highangle build me one? I am at a loss, I have been waiting do do this swap for a while, and this little, yet major thing is stopping me.. ARRGH!!
    Thanks in advance,
    John
  2. J.R.
    J.R. Guest
    Re: 10B swap to 14B SF -- U-joint ?\'s
    i just did the same swap last week, the 14sf uses a 3/4 ton joint. go to your local parts store, napa etc. and tell them you need a conversion joint for 1/2 ton drive shaft to 3/4 ton rear end. be sure you get the u-joint for your drive shaft that has the clips on the inside.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    or
    if you want good u joints stay as far from napa as possible and get spicers using these handy scans to find which ones you need
    <a target="_blank" href=http://community.webshots.com/album/22999281LAzgXBbByW>look up the 2 different applications here</a>
    <a target="_blank" href=http://community.webshots.com/album/22995567sqNVyxLTGX>find the conversion joint # and specs etc here</a>
    remember the view full size feature if the images are to blurry
  4. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    i can get you a shaft in less than 3 days shipped - if that's not quick enough call monday -i'll get you either a u joint from our shop to get you going quick or a part # - hope that helps-Jess
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    thanks i dont need a shaft yet.
    remember this goofy board you reply to each person directly and it emails them.
    unlike other boards where you reply to the thread
  6. drivelineman
    Aug 23, 2000
    707
    He he- that's right - was not trying to sell you - sorry to bother ya-Jess
  7. Scooter
    Scooter 1/2 ton status
    Nov 18, 2000
    551
    Grandview, Mo.
    I have an 87 Jimmy and swapped in a 14SF from an 85 3/4 ton burb. When I did this to mine I ended up using the 447 conversion u-joint.
  8. Storm Trooper
    Nov 24, 2000
    4,640
    Jess, I'm also going one ton but do not want to switch drive shafts yet. PM me your # so I can order the u-joints I need.
    I'll call you on Monday or Tues.
    87 K5, adding 14B FF and D60. 5:13 gears, 208/465
    Dave
    M j, nice charts....and info.
  9. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    My 86 will require 1310/1350 hybrid u-joint from High Angle.... dunno if this helps or not? But it might! /forums/images/icons/smile.gif
  10. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Either the Napa #348 or the #447.They are different.And about $30 each!!!
  11. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Thanks to all.!!
    Jesse, I may give you a call on Monday.
    Thanks again,
    John
  12. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    I got the conversion U-joint and it worked perfectly.. Thanks to all who replied.
    Jesse, I still want to get a new driveshaft for the Jimmy.. I'll give you a call about it.
    John
