10b u-joint life - update 2/13
Discussion in 'The Garage' started by alec78, Feb 7, 2006.
  1. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    It seems that for as little 4xing I do, I am going through axle u-joints rather fast. I put on about 25K miles over the last 20 months since I replaced this u-joint but it was fine before the last time I used it on a trail. I bought a Spice joint for the longer life and it died before the junk one on the other hub!
    It still has grease in it. I have yet to get into water. and I always loose a cap!!! Is this a sign? Am I missing something??
    Comments, questions and rude remarks welcome! Just help me fix this.
  2. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    is it installed correctly? what angle is it running at?
  3. alec78
    Aug 5, 2002
    358
    Washington
    Snap rings are in their groove.
    I guess I didn't actually say it, but these are the joints in the hub / knuckle.
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    are you reusing the same shafts? i wouldn't be surprised if after a failure your ears are deformed. i know when i blew a ujoint to pieces up front i didn't have a choice in reusing the shafts :haha:
  5. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    OK your sig says 10 bolts. What size tires are you running? I agree that maybe something happenned to the shaft when the first u-joint failed. So take close look. Aftermarket hardenned shafts arent that expensive.
  6. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Agreed, if you are simply spitting the caps out then most likely the shaft yolks are wallowed out.
  7. alec78
    Aug 5, 2002
    358
    Washington
    U-joint problem - Update 2-13
    I replaced the offending ujoint and found something. Granted I was using a ball joint / u- joint press, I turned the arbor BY HAND:eek1:!!! Is it just me or does that seem a little loose?
  8. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Prolly stretched the ears like everyone else said :-).
    Ira
