10blt 6lug to 10blt 8lug
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by badfish4tail, Nov 26, 2005.
  1. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
    okay i have a 10blt stock 6 lug on my rig now and have a donor rig with a 10blt 8lug, my question is would it be easier to just swap the axle's or switch out the parts from the two?
    Also i have a set of dana44 flat tops, will these fit on my 10blt?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes, the d44 knucles will fit your 10 bolt.
    it would be easier to swap the parts to make yours 10 bolts, that is if you don't have to swap the gears.
    all you have to change are the bearing hubs and the backing plates.
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Since your 8 lug 10b probably has 4.10 gears factory and your stock 6 lugger has 3.73's or numerically lower, it would be easier to just swap axles.
