10blt/D44 Q's????
Discussion in 'The Garage' started by southernspeed, Oct 29, 2005.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I'm putting flat top D44 Knuckles on my '78 10blt. Will the tie rod from the 10blt knuckles that mounts under the knuckles fit the D44 knuckles which mount from above? Are they the same size and taper?
    Thanks.
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    The physical dimensions of the taper are the same however IIRC the tie rod itself is straight on a 10 bolt and not on a D44, so as long as the tie rod will clear the springs you will be ok, if you have a lift i think it will work but if it is stock height then i don't think so.
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Thanks, sounds like good news as I'm putting a 4" lift and crossover on it.
