10bolt axle truss front
Discussion in 'The Garage' started by CHEVY 4WD, Jun 17, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I dont really know much about axle trusses but I would like to /forums/images/graemlins/grin.gif How do they help? do they cut down on ground clearance bad? where can I get one? why dont more of yall run them? and anything else yall might wanna tell me /forums/images/graemlins/thumb.gif
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    depending on the truss, they may work in compression or in tension, and they are there to keep the axle from bending under stress. Generally the below-the-axle models are the ones with thinner bars running the width of the axle, these are workin in tension. The ones on top of the axle (generally much beefier tube steel) work in compression.
    depends on the type... the below axle ones do reduce ground clearance... and worse, the tensile members arent very thick so when they meet a rock its bent-truss-city. Im sure the trusses that are basically full-width gusseting from the bottom of the diff out are tougher and more rock resistant.. but still, lost clearance sux0|2. /forums/images/graemlins/grin.gif
    ya got me. lol!
    depends on the person I guess. personally, I'm not gonna bolt anything to the underside of the axles. I wouldnt mind having an over-axle truss on my ff14b someday. AFA the D60 overaxle truss goes, no one really makes one... if someone has one its prolly a custom job. I think the MAIN reason that more peeps here dont run them is because unless you jump ur rig, a truss isn't really needed on bigger axles (d60/ff14b).
    i dunno... save ur money and buy a bigger front axle? /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
    j
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    They cut down on ground clearance if the truss is run on the bottom. How do they help? Keeps the axle together after airing it out.
    There are really some good threads on this.............
    One's here and and here and another one is right here and last, but not least, right here.
    Have fun reading..........
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    man, thats classic POR.. one post with about 50 responses... 5 of which are usefull... the other 45 are pointlessly mean smack talk and other childishness. gawd those llamas suck.
    j
  5. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Ya know, it's starting to calm down these days.....That actually turned out to be a good tech post minus all the BS. The other links are from RDC and there's some really great tech in those threads.
  6. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    if you plan on jumping your truck they are nessisary. i had one back in the day when i was young and stupid (about 3 months ago) and i jumped my truck a lot. now that i have "grown up" and like to keep as many tires on the ground as posible, i dont run one. they are about $130 from 4WPW for the con ferr super skid truss. it has a skid plate to protect your diff. this is what i used and never had any problames with breakage. but when you venture onto the rocks with this particular truss it will bend. but they are fairly easy to strighten out. hope this helped.
  7. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    Im thinking of the under axle truss now do they drag in the mud alot? I only want to run a 35 and I want it to go though mud fairly well btw im not worried about rocks(I live in FL)
