10bolt ball joints
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Redfrog, Jun 6, 2001.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    How hard is it to replace the ball joints (or king pins what ever you want to call them) in a 10 bolt ?
    any special tools to make it easier? I've never done it before
    and its time to learn how! before I break one. any hints to make it eaiser...
    HEY Fords!!! how many flushes does it
    take to get rid of you
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    They have to be pressed out. Get a manual and it will tell you how to do it. You can make a press out of some bolts nuts and sockets (the manual will show you how).
    '71 Blazer CST with alot of rust
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've done quite a few on Dana 44's, which really aren't all that different from a 10 Bolt. All you really need other than basic tools is a good seperator/pickle fork. An impact is nice, but hand tools work just as well. Expect to spend around 4 hours your first time, maybe more depending on the mood of the balljoint gods that day. Some people have handy little ball joint presses for tight ones, but a good dead blow hammer has always yielded good results for me.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.coloradok5.com>http://pugsley.coloradok5.com</A><P ID="edit"><FONT SIZE=-1>Edited by Pugsley on 06/06/01 00:25 AM (server time).</FONT></P>
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Pretty easy. I mailed you a write-up. It doesnt have any pics but has pretty good detail.
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
  5. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Ok, redfrog. I lied. I was going to mail you the write up but then I found that you dont have an E-mail add listed. So you can buzz me later with it or you can go here....
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com/balljoints.htm>http://www.nashvillek5.freeservers.com/balljoints.htm</A>
  6. Redfrog
    May 4, 2001
    753
    IL
    Thanks that helps a lot...
  7. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Make sure you understand the term "upper ball joint pre-load"
    oh ya I just made it up LOL
    Good luck
