10bolt crossover
Discussion in 'OffRoad Design' started by TxK5Blazer, Oct 1, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    Steve I am looking to purchase a set of knuckles from a member from a dana 44 "the flat top one" a matching set. I want to know what do I need from you and about what the cost would be. ORD has been good to me before and I can't wait to do buisness with them again.....Jason
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Here you go:
    steering arm
    pitman arm
    draglink
    end kit
    install kit
    total: $465
    Knuckle machine work is $60.00
  3. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    end kit
    Are you talking about the tie rod ends? If so are they the 1-ton Chevy's? Also, can you use the stock draglink ends for crossover or are the tapers and such different between the tie rod ends and draglink ends? Only reason I ask is because I just replaced my stock draglink ends and would like to save some money if I can.
    Ross
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup those are for the ends for the draglink, they're not 1-ton GM's, the GM 1-ton doesn't have a LH and RH end, one side is built into the tie rod. You can use draglink ends but the taper is different and the shank is a lot longer so you can't put a bend in the draglink to clear the crossmember. There have been some problems with the longer shank bending also.
    Those are the problems, the tapers can be changed for a few extra bucks, and you can order a custom draglink but it'll have to be straight.
    If these are problems you can deal with, you can use the ends you have.
