10bolt front backing plates
Discussion in 'The Garage' started by 77fixer, Oct 22, 2002.
  1. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    I was at the JY today and found an axle without hubs and I'm trying to figure out if it is 3/4 or 1/2 ton. Does anyone know the dimensions or any other way to tell them apart?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    By hubs, do you mean locking hubs?
    Because, if it's missing everything from the ball-joints out, it's the same piece of metal (3/4 ton or 1/2 ton).
    If it's just missing the locking hubs, count the number of lugs on the wheel mounting surface. 8 lugs = 3/4 ton. 6 lugs = 1/2 ton.
  3. 77fixer
    Nov 22, 2001
    464
    Meridian, ID 83646
    Everything was gone down to the spindle. I've been told the backing plates are different diameter due to larger rotors on the 3/4 ton.
    Brett /forums/images/graemlins/burb.gif
  4. heavy4x4
    Aug 28, 2002
    3,270
    Oooh, good thought. I guess I'm not sure then. Anyone else know?
  5. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    id get a half ton 10 bolt front spindle and compare sizes. good luck with that. /forums/images/graemlins/thumb.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've got a 3/4-ton 10-bolt in the garage. I just measured the backing plates for ya. /forums/images/graemlins/cool.gif If you measure from the edge of the bulges of the caliper mount, it's 13.5 inches to the outer edges.
  7. 77fixer
    Nov 22, 2001
    464
    Meridian, ID 83646
    Thanks, hopefully that will get me what I need. I'm taking my tape measure with me tomorrow when I pick up the air tank for OBA and check out some BBC heads.
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    When you look at one of the backing plates from the side, you'll see that it's sorta oblong where the caliper mounts. I measured from the top to the bottom, at the widest points. Good luck! /forums/images/graemlins/cool.gif
