10bolt hubs, mini-spool changed to open, spicer shafts/ujoints *pics* 8lug
Discussion in 'The Garage' started by jjlaughner, Aug 22, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    [​IMG] Locked
    [​IMG] unlocked, open diff
    [​IMG] Empty Housing freshly cleaned
    [​IMG] Spicer axle shafts and ujoints
    Now I need to know what to torque 10bolt ring gears down to? Do you use thread lock on ring gear bolts?
    The reason I pulled it down is I'm swapping on my flattops and 8lug stuff. I sold the mini-spool but the cross pin would not come out without pulling the gears off /forums/images/graemlins/tongue.gif SO, I need some hub bearings and maybe a couple new seals and then put everything back together once I run it through the parts washer /forums/images/graemlins/smirk.gif
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Re: locked, unlocked, open, empty, clean and spicers *pics*
    Here are some numbers for you.
    Cover Bolt Ft. Lbs. 20
    Pinion Brg. Preload In. Lbs 24-25 (NEW)
    Pinion Brg. Preload In. Lbs 10-15 (USED)
    Ring Gear Backlash .005-.009
    Ring Gear Bolt to case Ft. Lbs. 90
    Side Brg. Caps Ft. Lbs. 60
    Yes. I use thread lock, red. Then again I am /forums/images/graemlins/screwy.gif
  3. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    cool thanks! /forums/images/graemlins/waytogo.gif
    (actually forgot about the bearing caps torque specs)
    I just have to remember the bolts are left hand when I put it back in /forums/images/graemlins/doah.gif
