10bolt Ring and Pinion Help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Liberator, Sep 8, 2001.
  1. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    I'm currently trying to swap out my 3.08s in the 10 bolt up front to match the 3.73s in my 14 bolt. I'm having problems getting the ring gear off the carrier! Any suggestions besides taking it to a shop with a press?
    Bo
    If it breaks, it wasn't good enough!
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    WEll, after you have the ring gear bolts removed. (They are reversed threds by the way, case you didn't know that) then uou should be able to take a dead blow hammer or rubber mallet and knock it off working it all the way around to get yourself a gap between the gear and the seat on the carrier. Then you can use flat head screw drivers to pry it up or down whichever way your waorking on this thing and it should come right off. Make sure you dont let it hit the ground. Might chip a tooth.
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. dyeager535
    26,979
    Loosen the bolts. (were these reverse threaded? I know the cars are) Loosen the bolts JUST so the head is off the carrier. Pound on each bolt across from each other, just like tightening lug nuts. Keep loosening the bolts as the gear works its way down. you don't have to get it too far down before it will just fall off.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Yes they are reverse thread. And, the lip on the diff that is holding the ring gear is only about 1/8". So, you don't have far to drop before the ring gear will be loose. Then, just finish removing the bolts and remove the gear.
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    Who put a stop payment on my reality check?!?
