10bolt to 12bolt brakes.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sammy, Mar 8, 2002.
  1. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    I wonder if I can use brake parts, like the cilinders and the bakes them selves and stuff of a 10bolt rear in a 12 bolt rear.
    The brake parts on the 12bolt are a bit. uh. well. gone or rotten.
    Thanks in advance.
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I unbolted the backing plates from the 10 bolt with everything attached and bolted them onto the 12 bolt. It all worked just fine. It was a direct bolt-on for me.
    John
  3. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I will second that, I did the same thing, just unbolted the backing plates with all the brake stuff still attatched and bolted it right on to the 12-bolt.
  4. Sammy
    Dec 8, 2000
    250
    Perfect. This will save me alot of time. Thanks guys.
