10bolt to d44 question
Discussion in 'The Garage' started by SUB-ZERO, Nov 24, 2005.
  1. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Will front calipers,pads and locking hubs from a 10bolt fit on a front d44?
  2. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    Yep. 10b's and D44's are the same from the knuckle out... now, there are a coupla flavours of spindles and such ... but the parts you mention should cross right over.
    -- A
  3. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    the calipers are slightly different, but they should work on either axle, considering the caliper mounting brackets are the same. also, the brake line fitting is different.
  4. dremu
    Feb 27, 2000
    15,963
    454
    Crap! I forgot about the damn plumbing ... IIRC, later D44's had the other style caliper too. Anyway, the caliper will physically fit, but you may have hose issues, yes.
    -- A
  5. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    When I swapped the D44 in to replace the 10bolt, we had to swap the caliper brackets. The 10bolt calipers didn't seem to want to fit the D44 caliper bracket. It's no biggy, though.
    This was a D44 from a 76 blazer.
  6. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Yeah, I'm puttin' a d44 from a 77 into a 87 Jimmy.
  7. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    To get my 10 bolt calipers to fit on my D44 I had to grind off a molding tab on the bottom of the caliper. After that, they bolted right up. :D
    Rick
