10bolt Torque specs?
Discussion in 'The Garage' started by Fry, Nov 15, 2003.
  1. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    Anybody know where I can find them, I tried searching here and some different search engines but keep getting nothing concrete.
    I'm going to try to finsh my 3/4 ton swap but I need to get this diff together and ready to swap in.
    Can anybody help?
  2. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    Edit...
    I narrowed down my search and came up with some good info. So I guess I'll just post this up here for the next people searching
    Q Anyone know the torque spec on a 10 bolt front axle for the inner and outer hub nuts?
    A Tighten the inner to 50 ft/lbs while rotating the rotor. Back off the adjusting nut and retorque it (35 ft/lbs for auto hubs and 50 for manual hubs). Outer locknut gets tightened to 160 ft/lbs
    Q: What is the main cap torque?
    A: Cap bolt torque is 60 ft-lbs
    Q: How to setup a pinion?
    A: When setting up a R&P, the pinion preload should be about 12-15 in-lbs. That is after the 400 ft-lbs or so it takes to crush the collar. Since you can't check the preload (can't do that with the carrier and ring gear in place), I would agree to crank it as tight as possible. Then, keep a CLOSE EYE on it for a bit. If it isn't tight enough, it will back itself off.
    I also found this info
    http://www.ring-pinion.com/tech/techg0798.html
    http://www.ring-pinion.com/tech/techsetupspec.xml
    http://www.ring-pinion.com/tech/techg0698.html
