10mm or 7/16 banjo bolt for Chevy 1/2 & 3/4 ton calipers
Discussion in 'The Garage' started by BlitzK5, Jul 30, 2005.
  1. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    I ordered the 14bolt FF disc conversion brackets and the stainless brake lines with the 10mm banjo bolt from off road design. I just check my 82 brakes that I was going to be using and realized that it takes a 7/16" wrench for the bolt (11mm fits even snugger though). Does this mean I needed the 7/16 banjo bolt or will I be ok. Does it go by the wrench size or the threads? I ordered the 10mm because there was a question on here before about which ones to use before and everyone said that stock calipers used 10mm and refurbished ones used 7/16 ones. And since mine are the originals I said 10mm. Now I am afraid I was wrong.
  2. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    IIRC, your year should be the 10mm banjo bolt.
