110v welders any good for bodywork?
Discussion in 'The Garage' started by little79k5, May 30, 2002.
  1. little79k5
    little79k5 1/2 ton status
    Mar 27, 2002
    230
    panama city, fl
    i have to replace my rear floor and want to do it myself. are these 110v gasless mig welders i see for $200-250 any good for this kinda work?
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Yes, I am no welder. Just started welding a couple of weeks ago.. I used a lincoln 110v gasless to feel in all the holes left from the body trims.. It worked great and I had to turn the cycle way down..My .02...Dan
  3. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Will work fine. Use .024 wire and you'll be golden (all good).
    Boss
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i have a gasless mig i bought from sears.it was only 199 dollars.ive welded in floorpans and done some minor body repair.i have to run it on low so it wont burn holes.
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    You bet. I use a small Lincoln, works great to 3/16, 1/4 inch stuff, you may need to make more than one pass. You can burn holes thru 1/8 inch (.120 wall) if you're not careful.
  6. wheelin72
    wheelin72 Registered Member
    Mar 6, 2002
    97
    Hanford, CA
    I have a 110 with gas lincoln
    I turn the heat all the way up
    its actually best so u get a low build up bead that is strog and lesst o grind
    warping is a big problem. I wait until the weld is cool to tough before i doanother tack
  7. little79k5
    Mar 27, 2002
    230
    panama city, fl
    thanks for the info
