12:00 position Timing Tab Source?
Discussion in 'The Garage' started by Russell, Apr 11, 2006.
  1. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    hey guys!
    I bought a harmonic balancer for my truck, which was a crate engine pulloff. However, it winds up it is a 12:00 timing tab position balancer, instead of a 2:00 position tab.
    I've looked all over ebay, Summit, Jegs etc and have seen no mention of an aftermarket bolt on type tab for a 12:00 timing position.
    I know they exist, my 80 had one stock, but it was spot welded to the timing chain cover, which I recently tossed (:doah:)
    Any ideas where I can get one that is a bolt on type deal?
  2. dyeager535
    26,979
    Did you check GM performance parts online?
    Just an idea.
  3. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
  4. Russell
    Jun 23, 2000
    7,923
    333
    I would just time it with my vac gauge, but my engine is running tuned port, and I need it set at exactly 6 degrees base timing. Unfortunately, that is a far cry from where the engine will produce the best vaccum.
    Those covers seem like they might work, but at that price, I'd be best to just go find a new balancer with the 2:00 mark on it.
    I tried calling a few local stealerships, and one of them had any idea what I was talking about, and tried to sell me the 2:00 tabs, or passed me on to their service departments (like what are they gonna do about it? LOL)
  5. dyeager535
    26,979
    You've got a scanner or winALDL, right?
    Just figure base timing out from that! :)
  6. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    How do you set timing with a vacuum guage?
  7. Russell
    Jun 23, 2000
    7,923
    333
    Advance / retard the dizzy until you get your best vaccum reading, then retard it a touch until it stops pinging under heavy acceleration.
    How would a guy determine base timing based off my scanner? The ECM assumes that the timing is already set at 6 degrees initial correct?
  8. dyeager535
    26,979
    I believe that some are different, but most applications from what I recall the ECM assumes timing is at base, and adds whatever is called for in the timing tables based on load, etc. Idle RPM/timing advance I would think would be pretty easy to figure out.
    I can't recall what exactly you are running for heads, but don't be surprised if it doesn't like base timing anyways. My setup certainly doesn't like the stock timing/fueling tables.
