12.5" wide tire on 8" rim (Iknow it's been asked before and I searched)
Discussion in 'The Garage' started by 88K5Jimmy, Sep 2, 2003.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    12.5\" wide tire on 8\" rim (Iknow it\'s been asked before and I searched)
    Looking to put 35x12.5x15 MTR on a 8" wide factory rally wheel. The specified rim size is 8.5"-11". Would I need to run a lower tire pressure to get the tread to flatten out?
    I know it's been discussed but my searches came up empty.
  2. Ruff_ryda_420
    Ruff_ryda_420 Registered Member
    May 22, 2003
    19
    alberta
    Re: 12.5\" wide tire on 8\" rim (Iknow it\'s been asked before and I searched)
    i wouldn't sweat it. i've got my 38.5x14.5x15" swampers on stock rallye wheels, so a 12.5 should be a breeze.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i run 28x13x16 on 6.75x16in rims and i have nice even tire wear i run 24psi on the street and 12 on the trail and 6 in the sand /forums/images/graemlins/thumb.gif
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I run 42x15.5x15s on an 8" wheel, they flatten out nicely at around 5-7 psi... /forums/images/graemlins/laugh.gif And I have yet to blow a bead.
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    same here i run 6psi in the sand and have yet to loose a bead /forums/images/graemlins/thumb.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I ran my 35" BFG M/Ts for years on 8" wheels. I now run 16" wide 38.5" super swampers on 10" wide wheels.
  7. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    This would be on a daily driver so I would need all the miles I can get out of the tires. So I need to keep the bad tire wear down to a minimum.
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    once you get them on run them through a mud puddle and check the tread pattern on the street and adjust the tire pressure till they leave a even tread pattern on the street /forums/images/graemlins/thumb.gif
  9. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Not a problem, I run the exact same setup on my rig, on an 8" rim and don't have any problems with the setup. I run about 15 to 20 psi on the trails and have yet to roll a bead.
    Rob
