12 bolt 1350 yoke
Discussion in 'The Garage' started by big4x4ride, Mar 20, 2005.
  1. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    Anyone know what companys sell a 1350 Yoke for a 12 bolt?
  2. big4x4ride
    Feb 11, 2004
    216
    Corpus Christi, TX
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i know the 10 bolt and 14 bolt sf share the same spline and seal diameter, and iim sure the 12 bolt is the same. so you should be able to get one from a junkyard off a 3/4 ton truck
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Look for 12 bolt trucks with clutch pedals still in them in junkyards , that yoke should fit the bill for you :k5: :k5:
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Most 12 bolts with manuals do not have 1350 yokes. Only the manuals from 1/2's with 465/208 setups will have 1350 yokes at the pinion. The 10 spline (203's & 205's) 465's will most likely have 1310 yokes at the pinion.
    Randy's R&P may have 1350 yokes for sale for a 12 bolt. If not NWF may know where to get them or HAD. Call some local shops too. They are out there in the aftermarket.
    Harley
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    They are readily available in the after market like you said .
    They cost though .
    129.99 at Currie
    150.00 at Natl d-train
    95.71 Chassis engineering
    Even though car and truck 12 bolts are different , the splines on the pinion , and definitely the oil seal for a 1350 , should be the same , and jegs has 1350 yokes for 85 bucks NEW .
