12 bolt 4.10 3 series carrier
Discussion in 'Parts & Trucks Wanted' started by Tom E, Jan 16, 2006.
  1. Tom E
    Tom E Registered Member
    May 25, 2005
    77
    Columbus, GA
    I'm trying to located a used 4.10 ring and pinion set up for a series 3 carrier (thick gear), or 4.10 with a 4 series carrier. If you got one taking up space in the shop let me know what it would take to help you clean up. :p:
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have one open carrier.
    $40 to your door.
    Iceman
  3. Tom E
    May 25, 2005
    77
    Columbus, GA
    I need thick 4.10 gear (to use with my 3 series) or standard 4.10 with 4 series carrier. Anyone got a 4.10 to go with iceman's open carrier?
  4. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    4.10' ring and pinion
    I have a set of 4.10's (very good shape ) out of a 14 bolt FF
    how would I be able to tell if they are the set you need ?
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Easy, 14b ff is 10.5 inch ring gear
    12b is 9.25 inch or 8.75 I can't remember, so that means it won't work.
    :D
  6. Tom E
    May 25, 2005
    77
    Columbus, GA
    Nobody ? :eek1:
  7. Tom E
    May 25, 2005
    77
    Columbus, GA
  8. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    One question are you looking for just gears or gears and carrier. I have a complete ready to drop in set that has the 4.10 gears and carrier with the pinion installed in the pinion support so all you have to do in install the pinion carrier into your axle with your pinion shim and drop the carrier in adjust to the factory specs. $175 for the complete ring gear, pinion in the pinion support, and carrier. If interested leave a pm.
    bigred81
  9. Tom E
    May 25, 2005
    77
    Columbus, GA
    I'm looking for just ring and pinion
