12 Bolt/5lug to 6lug swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Nov 21, 2002.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Are the 5 lug axles out of a 12 bolt the same as the 6 lug 12 bolt axles?
  2. Grim-Reaper
    7,385
    Atlanta
    After 73 they should be as long as it's not a van axle. Just measure the lenghts of the shafts and make sure they are correct. I have a 70 axle here that is 3/4 of an inch less wide then our axles and it did come out of a truck and not a car.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yeah my friend just did that swap a few months ago, it was a 77 and they were the same length.
  4. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I put a 12 bolt in my 2WD truck that came out of a 4WD, all I did to make it a 5 lug was swap out the axle shafts and drums. So it would be the same going from 5 to 6 lugs.
