12 bolt axle shafts- vertical play at axle bearings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FWP, Apr 24, 2002.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    While doing an inspection of the rear system, I noticed some play up and down, on both axles. Maybe I never noticed it before, but I'm curious. It's about .002 - .008" (somewhere in there) up and down (I didn't mic it, just by feel). The bearing surfaces look good, and the shafts aren't scored. Is this a normal thing, or am I being paranoid/forums/images/icons/laugh.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    There is a certain amount of "vertical" play that is acceptable and if you only have .002"-.008" that is good.
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    better than the .30'' we had on or2plays 12 bolt. but then we put a 14 bolt and disk brakes under it. now i have a bad trailer axle...
    ill fix it... some day... maybe.
    grant
