12-Bolt Axles
Discussion in 'The Garage' started by avgas, Jul 17, 2003.
  1. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    Are all 12 bolt's factory limited slip? if not how do you identify a factory LSD?
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    No....
    Absolute best way is to pull the cover....
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    my first and second 12 bolt were open and the 3rd was a limited slip.my fourth and hopefully final rear diff i changed to a 14 bolt ff.if you open the diff cover and see clutches with springs in the center then it is limited slip.if you see 4 gears then it is a open.
