12 bolt axles?
Discussion in 'The Garage' started by jedifish, Feb 22, 2004.
  1. jedifish
    jedifish Registered Member
    Feb 14, 2004
    12
    /forums/images/graemlins/usaflag.gifI know that the front axle of my 84' K5 is a 12 bolt, but what should the rear be? Is this normal to have a 12 bolt front for that year? So should the rear be a 10bolt or the same as the front? I want to know cause I am still learning about this K5. and want to know what is not original. Thanks!!
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    No 12 bolt front axles were ever made unless someone had one custom built in the aftermarket. Your front axle should be a Dana 44 or 10 bolt. An 84 should have a 10 bolt front. The original rear for that truck should be a 10 bolt also. There is an axle identification guide in the tech section of the main page here.
    Harley
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Congradulations, on the 12 bolt front, you are one
    of only three that I know of.
    Are you sure its a 12 bolt front ?
    Also welcome to CK5 !
  4. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Welcome!
    There are many technical articles available in the Tec section of ColoradoK5.com. The one you want to look at is the axle identification guide.
    That should help you identify your axles.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Sweet! The elusive front 12 bolt has reared it's ugly head again! /forums/images/graemlins/peace.gif
