12 bolt carrier question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Apr 11, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I have a lead on a 12 bolt rear with 3.07 gears. What is the lowest gear ratio I could go with without changing the carrier?
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I'm not sure but I seem to remember seeing 3.73 as the cut-off for 12 bolts. Go to summit.com or jegs and look up R&P's they are usually listed by carrier size if it is a factor.
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-700R4-241-33" BFGs-10 bolts w/4.10's
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  3. extremeblazer
    extremeblazer 1/2 ton status
    Dec 5, 2000
    129
    Albany NY
    The 12 bolt rear axle had three different carriers used. The first was for 2.73 ratios only, the second (yours) is for 3.07 to 3.42 ratios and the third is for 3.73 to 4.56 ratios. Thicker gears are made that will mount on your 3.07 to 3.42 carrier. So you can go up to 4.56 if you want you just need the correct part number.
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Do you have any idea who makes the gears that will fit?
    89 K5 Silverado
  5. DaveDave
    DaveDave 1/2 ton status
    Feb 8, 2001
    247
    richmond gear part no. 69-0167-1 for 4.56
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    I think just about any gear mfg makes these style of gears, but I would spring for the extra cabbage and go with Richmond...
    Mike - <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>[​IMG]
