12 bolt carrier
Discussion in 'Parts & Trucks Wanted' started by mdm365, Jul 24, 2002.
  1. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    does anyone have a 12 bolt chevy carrier need one real bad.please e-mail me mmdm563@hotmail.com
  2. mdm365
    Jul 2, 2001
    536
    mineral wells wv
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    only 3 hours and bumping to the top.../forums/images/icons/confused.gif
    quick question though. What ratio do you need? I think the carrier is only good for a certain range (like 3.07-3.73).
  4. mdm365
    Jul 2, 2001
    536
    mineral wells wv
    kenny the the 12 bolt has 308s I cant find a good rear carrier the passanger carrier bearing spun on the carrier snout and the bearing slides right on.found one brand new but not in the buget 400.00 dollars for and open diff.live in vegas things are high here.thanks oh ttt sorry need this thing bad got to move the thing from mt brothers before this wednesday.
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I've got a 12 bolt carrier with a 3.08 ring gear on it....It's welded though, and the bolt that holds the cross pin in is busted off in the carrier...If you want to mess with all that, you can have it for the cost of shipping......Another option is to check e-bay....You can find those things on there quite a bit. Good luck. /forums/images/icons/smile.gif
  6. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    I am sure i can hook you up but i want 2 dbl check 2 make sure willl check in tomorrow night with what i got
  7. kennyw
    Jun 9, 2002
    13,223
    94
    I have a 12 bolt with a bad pinion bearing. It had 3.73 gears but the carrier should be the same as yours. As long as it checks out good $25 + shipping and you will be able to tow the truck at a minimum.
  8. crossy
    crossy 1/2 ton status
    Jul 12, 2000
    257
    southern ,N.J.
    let me know if you still need a good one .I tried your hotmail it it got kicked back. DAVE
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    3.73 carriers are not same as 3.07 carriers, the split is from 3.40 to 3.73
    2.76-3.40 use series 3 and 3.73-4.88 use series 4
    the difference is in the mounting flange for the ring gear where its located from one or the other end of the carrier, they are about 1/2" differnce from 3 to 4 series, IE the ring gears for series 4 are way thinner than for series 3 because of how small diameter the series 4 pinion gears are, they tried to fix some of it by moving the ring gear mounting surface on the 4 carriers over to compensate for that to a degree, you can tell the difference between both series with a tape measure. series 4 carrier gear mounting flange is 5" away from the outside edge of bearing thats pressed on to the end of the carrier farthest away from it.
    series 3 wil be about 5.5" distance.
    go to randysringandpinion tech section to learn why and how this works.
    personally i have yet to see a truck 12 bolt that has 3.08, always use 3.07 from what ive always seen,
    the 8.5" 10 bolts maybe used 3.08 however
