12 bolt corp limited slip
Discussion in 'The Garage' started by supernaut, Aug 31, 2005.
  1. supernaut
    supernaut Registered Member
    May 2, 2005
    94
    Seattle, WA
    I am going replace the diff oil in my stock front dana 44 and stock rear limited slip 12 bolt corporate. My manual doesn't seem to say anything about what oil to add to the stock limited slip....'75 k5 w/stock axles. I've read there is an additive you need to put in with the regular gear oil. Anyone know if that's the case?
    I'm planning on cleaning out the diffs of all old gear oil and metal debris, etc and putting in synthetic 75w90...
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    Friction disk limited slips need a friction modifier, you can get it in a small tube at most parts stores
