12 bolt diff. questions
Discussion in 'The Garage' started by odoa3, May 4, 2004.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I was given a 12 bolt axle. It has an open diff. that I was planning to weld and put in my 12 bolt. I have a trashed Eaton posi in it right now. My rear end is a 3.73- I believe the open diff. is a 2.7? (can't remember the last number right now). The question- can I just use the 3.73 ring and pinion in the open diff carrier? Or, do I need a different carrier? First attempt at diff work so be merciful! /forums/images/graemlins/dunno.gif Thanks!
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Youd have to check what the carrier breaks are, I dont remember off the top of my head.
  3. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Any idea where I could find this info?
    Thanks.
  4. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    Case Changes,
    2.73 and down, Low 3.07-3.42 and High 3.73-4.56
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Case Changes,
    What he said! /forums/images/graemlins/waytogo.gif
  6. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Case changes? You mean the carrier itself, correct? So no way I could use the 2.7? carrier with the 3.73 gears, right?
    Thanks for the info.
  7. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Correct. The carriers for the 3.73's are quite common......shouldn't be too difficult to find the one you need. /forums/images/graemlins/waytogo.gif
