12 bolt disc conversion. yes, I searched.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MOABDADC22, Dec 1, 2004.
  1. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Does anyone have a list of parts needed to do an inexpensive (ie, cheap) rear disc conversion on a 12 bolt?
    I manage the local autozone, so I can get screaming deals on parts.
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
  3. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    And this is the thread in the Bloody knuckle clickorama
  4. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    I'm in the process of finishing this version up. It's the Autozone version...
    http://www.wrath.com/4x4/tenboltreardiscbrakes.htm
    If you are using 10bolt calipers for this...try using 84 cavilier brake hoses and banjo bolts.
    (the link is to the 10bolt version, but the 12 is the same thing.)
    Any backing plate will work, I'm using old 10 bolt ones. I removed the dust sheild from them.
    Blake
  5. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    I have this one marked as favorite: brakes
    It's the same one that ColAdo82K5 linked. /forums/images/graemlins/doah.gif
  6. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    How does the caliper attach to the backing plate?
  7. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
  8. ColAdo82K5
    Feb 18, 2000
    789
    MO
    The backing plates that are used for the conversion are stock FRONT ones...
    SO. That means that they use stock front hardware, i.e. the allen head guide pins and bushings.
    Blake
  9. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I demand a $10 royalty for using my tech article. haha.
    Yes, you use a front 6 lug D44/10 bolt backing plate. There are 3 generations of these.
    I like G-body hoses because they're nice and short (and cheaper than anything else I found). Less rubber = less expansion.
    Pretty simple... just time consuming.
  10. ColAdo82K5
    Feb 18, 2000
    789
    MO
    I've seen the G-Body ones, but ran across the early 80's chevy cav brakes hoses while selling them. They are even shorter and don't have any hard line built into the line. They take a standard u-shaped clip to hold them in as well.
    The $10 check is in the mail !
    Blake
  11. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Hmm...
    I'm pretty sure my G-body ones don't have any hard line in them and I used the funny looking horseshoe shaped thing to hold the line also.
    I'll have to look in the daylight tomorrow.
