12-bolt full float conversion
Discussion in 'The Garage' started by Mastiff, Feb 10, 2004.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Can anyone tell me about the Warn 12-bolt full float conversion? Is it worthwhile? Can I install it in my garage?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    No offence, but why when a 14 bolt FF can be had at such cheap prices. /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif I don't knock anybody for doing something different, but cost vers effect and a 14 bolt FF is the clear winner in my view. /forums/images/graemlins/deal.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes. It's discontinued AFIAK.
    Is it worthwhile?
    You mean WAS it worthwhile? Nope, 14 bolt full floaters are a dime a dozen.
    If you can find one and have a welder, that's a possibility.
    Ok, my turn to ask questions.
    Why would you waste money on a 12 bolt with tiny pinion bearings and an 8.875" ring gear when 10.5" 14 bolts are cheap, easy to swap in, and way stronger than any full floating 12 bolt.
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Well, the only remark made relevant so far was Tim's discontinued, which I've heard; all the other are idiotic.
    Crawlin70 did it to the 12 bolt he ran in his rig before he dismantled it. You may want to PM him and ask him about it. I don't know if he kept it or got rid of it, but he reported no problems with it.
    As for other conversions, I do know of another kit, but can't recall it off the top of my head. There is a homebrew FF 9" idea that could probably convert a 12 bolt to FF.
    This is just an example of what Crawlin70 threw towards his 12 FF
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I checked today actually out of curiousity and the 12 bolt is no longer even listed in the Warn catalog which is why I had thought it was discontinued.
  6. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I knew I'd get some flak for asking this! /forums/images/graemlins/tongue.gif /forums/images/graemlins/wink.gif
    I only have 35" tires and a mild 350. I have been thinking about 14ff, but with "small" tires, the diff will practically be dragging on the ground. Seems like overkill. Plus, even if the 14ff is cheap, I'll need new gearing (4.56) to match the front, or else new front gears (4.10 maybe?) to match the back.
    Or I could just leave it alone since I don't really beat on the truck too much anyway.
  7. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I think it was because Warn was overly proud of the kits $$$$$$........ /forums/images/graemlins/waytogo.gif
  8. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    I think Mudzer did the full floater conversion on his 12 bolt. He now has a 14FF. Not sure why he got rid of the 12 bolt, I don't know if it broke or he just upgraded. Hopefully he'll see this and fill you in.
    IMHO, I would go to a 14FF. If you really want to stay 6 lug, 14FF with the 6 lug adapters I've heard of around here or a 14SF. I definitely wouldn't throw money at a 12 bolt. /forums/images/graemlins/doah.gif
  9. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Can the 14ff drums (with adapter) fit in a 6 lug aluminum rim? Does the adapter push things out and make more load on the bearings from the leverage?
    What are guys doing with their front axles when they get 14bff rears? I can see picking up a 14bff cheap at a junk yard, but a D60 front is mucho $$$, no? Just live with the 10?
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Most of the adapters do push the wheels out more. But that evens out the track width. As far as bearings go, I (along with a lot of others) run heavy offset rims (3" or less bs) with very few wear issues. I only see bearing issues if it is loaded down with a lot of weight and a good size trailer.
    There is the superior axle upgrade option (robzilla is runnning them now). They are by far cheaper ($125 ea) than buying and regearing a 14FF or a warn kit (can't find it new any way). There is an impressive gain in strength also. You can keep your 6 lugs and all. If I had my heart set on a 12B that is the way to go. Just keep a spare shaft (L & R are equal in length and such) in the extreme event you break one.
    My .02 though
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] If you have 4.56's up front, then look for a 14 bolt FF with 4.56's. They can normally be found in M1008's I think, not sure, I'm no expert. Ground Clearence, I'll only be running 36's for then next few years, and I'm going 14 bolt FF.
  12. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Well, the only remark made relevant so far was Tim's discontinued, which I've heard; all the other are idiotic .
    [/ QUOTE ] Still with the name calling huh ?? Not everybody will even consitter defiling a Chevy with a furd 9". /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  13. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Heres an adapter thats C7C machined for 6 lug but kinda spedy! web page Ask Grady about C&C 14BFF Hubs that are 6 lug conversion.
    Bill
  14. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    As far as the front end goes, you either find a 3/4 ton front (10B or D44 will work) Or find the caliper brackets rotors hubs and such. (all internal style hubs use the 1/2 ton spindle)
  15. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
    i am swaping to a 14 bolt ff in a few weeks. up front i have already swapped in a dana 44. i will be running 4.10's and 35" tires. seems to me like it will be alright. sure the pumpkin is a little large, but you can chave a little off, and the strength trade off seems to be worthwhile.
    sean /forums/images/graemlins/waytogo.gif
  16. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    I have the Warn kit on my 10 bolt. I have 35in MTRs, lmtd slip frt & rr, stock 5.7, 700 w/shift kit. I bought frt & rr 10 bolts from a board member about 2 years a go, already built. I am not a serious wheeler. My rig is my daily ride. I've logged on some miles on the 10 bolt ff setup no prob. Drove it from San Diego to Vancouver Wa and back. No problem. Tows my boat no problem. Gets me to work & play no problem. If I had the money I would go D60 & 14b W/4.88'S and new tires & wheels to match. Thats a lot of cash. Get an after market lmtd slip unit or a locker and with regular service (fluid changes) you'll never here from it again. Throwing a 14b rear at it is a solution but not the only way to go. You can get a 14b for $100. Unless you want to run someones junk you'll need to freshen it up. Add money. Tires & wheels. Add money. Convert the front to 8 lug. Add money. 8 to 6 lug adapter /forums/images/graemlins/tongue.gif Will your wheels clear the drums ? I would say yes on the 12 bolt. How many Big Block GM muscle cars have 14b rears ? None. 12 bolts. If you have a problem with your right foot and your makin some horse power, 14b. Otherwise upgraded stock will work fine.
  17. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    just an fyi it is C N C not c&c /forums/images/graemlins/shame.gif . cnc=computer numerically controlled . sorry just a pet peeve. /forums/images/graemlins/whistling.gif /forums/images/graemlins/dunno.gif
  18. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I checked into the same thing a while back as I'd already regeared my 12bolt and D44, and added rear disk brakes. So costs for 14ff (paying for install too) was gonna be pricey.
    Anyway, Warn discontinued the 12ff kit, but I had a long talk with ORD not too long ago and they've been sorta thinking about maybe putting something together - if there was enough interest I suppose... There is also a way to do it yourself and maybe they'd tell you how if they aren't thinking about going into production anytime soon. Worth a call anyway. If you do call, please apologise to them for me if posting this let any cats out of any bags... /forums/images/graemlins/crazy.gif
  19. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I can't sleep so I just had an idea. With a little work someone could bolt spindles and backing plates on the rear axle housing and run a mirror image of the fronts, the only EXPENSIVE proposition would be getting axleshafts made and sealing it up good. Which is maybe why no one does. But if you convert to disc brakes the current way with regular axles, wouldn't the caliper and rotor hold in the axle anyway if it broke /forums/images/graemlins/thinking.gif
  20. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    An old boy up around Canada way did the similar thing to a 9" that I previously mentioned.
    He used D44 hubs and spindles, had a set of whatever machined. It's too early to describe it, here's the link.
    I really wouldn't go by the price this guy listed. I have come up with a ball park figure and if I was to do it right now, I'd be looking at another $5-600 to convert my 9" over this way. On top of that, I really don't like the design, since the spindle has to be pulled in case of a broken shaft.
