12 bolt gears?
Discussion in 'The Garage' started by alf4444, Oct 13, 2005.
  1. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    are gears for a 12 bolt out of a car the same as the 12 bolt trucks? there are a few ring and pinion sets on ebay I'm thinking about bdding on
  2. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    No, they are different. The pinion gear on a car model is shorter than a truck model. Ring gear is the same, though.
    Jimbo
  3. Lonnie P
    Lonnie P Registered Member
    Feb 7, 2005
    28
    Pittsburgh, PA
    The pinion is not shorter.....
    It has a larger stem diameter which makes it stronger. Seems odd the car gears are stronger than a truck, but it is fact.
    You can use car gears in the truck by using a special bearing set. I do these routinely on trucks for more strength. Drivetrain Specialties (DTS) can hook you up with the required install kit.
