12 bolt help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JDELBLAZ, Nov 3, 2000.
  1. JDELBLAZ
    JDELBLAZ 1/2 ton status
    140
    STAMFORD C.T
    I just bought a `72 12 bolt rear and I am trying to remove the axle's. The problem is I removed the center pin in the carrier now need input on how to remove the c-clips. I can move the axle in and out once c-clip doesn't move at all and the other just spins. How do they come out? Your help would be greatly appreciated. Thank you.
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    The C clips should just slide off. if you push the axles in so the C clips clear the spider gear they should almost fall out. I had that happen on my old S-10 Blazer. Bye Bye wheel and axle![​IMG][​IMG]
    The clips are actually U shaped and just slide onto a slot on the end of the axle, there is a recess in the end of the spider gear that prevents them from falling out when the cross shaft is in.
    Rene
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Like tRusty said, but rotate the carrier a little. The same thing happened to me when I first had mine apart. I wondered why it didn't slip right off[​IMG], there's only one way they come out with the axle pushed in.
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
